HI geoff
I did a new install of the kicadwinbuilder from scratch
Run the make.be
this is the log in the cmd screen at the end, same error as yesterday:
If i try runkicad, it say that ./kicad is not found
Would it be possible to help me ?
[ 46%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/dialogs/d
ialog_fp_lib_table.cpp.obj
ialog_fp_lib_table_base.cpp.obj
ialog_fp_plugin_options.cpp.obj
ialog_fp_plugin_options_base.cpp.obj
[ 46%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/dialogs/w
izard_add_fplib_base.cpp.obj
izard_add_fplib.cpp.obj
Linking CXX shared module _cvpcb.kiface
cvpcb\CMakeFiles\cvpcb_kiface.dir\build.make:816: recipe for target 'cvpcb/_cvpc
b.kiface’ failed
CMakeFiles\Makefile2:780: recipe for target 'cvpcb/CMakeFiles/cvpcb_kiface.dir/a
ll’ failed
Makefile:115: recipe for target ‘all’ failed
– Installing KiCad locally. Use RunKiCad.bat to run this version
CMake Error at KiCadWinbuilder.cmake:1038 (file):
file COPY cannot find “C:/kicadbuild/kicad/bin/pylib/_pcbnew.pyd”.
