Hello world,
I’ve done schematic with hierarchic pages.
In racine page, I want connect each module. I use pins hierarchicals, but DRC give me an error, yet, I am connected, I don’t understand my problem.
Thank you for your help
Posting another screenshot does not help much. For analysis we need the project itself.
It is not very difficult to make a copy of your project, remove most of the clutter and then zip it up and post it. You don’t need all those sheets and what is on them to troubleshoot a hierarchy wiring problem.
sorry, I don’t understand, only my hierarchy schematic ?
Ì have replace hierarchical labels by global labels, and ECR is correct now, I don’t know if it is a good method ??actually I think I didn’t understand how to use hierarchical labels. I looked at the doc though.
Global labels work, but those do not help to understand what is wrong with the hierarchical labels. To diagnose the problem with that, the minimum needed is the project file, the root sheet and a few of the hierarchical sheets that are connected with those labels.
Yes, that is likely. I think I know what the (most likely) causse of your problem is. You probably placed hierarchical labels inside the “sheet connectors”.
Do this:
Restore a backup in which the hierarchical labels are still used.
Delete the labels inside the boxes in the root (= main) sheet.
Right click inside one of the sheet rectangles, and then choose Import Sheet Pin.
Place the pin (it is always on the edge of the sheet) and repeat step 3 until all pins are imported.
