Hi.
Just realised that Kicad whisperer in Global Label Properties is crazy. It’s not possible to make “FAN” label, when there is “Fan_pres” label already in the schematic. The wisperer is way too agressive and changes everything what I write.
Make “Fan_pres” global label and place it in the schematic
2.Try to make “FAN” global label
3.Don’t anger too much
I can change the name to the same, but this could be problem anyway.
Omg please let us turn this off it’s driving me insane on a large project. It’s not just that it’s aggressive, it’s also almost always wrong as well. I make a label with LCD_CS then try to add LCD_SCLK LCD_SDA LCD_TE etc and now it decides EVERYTHING that starts with ‘LCD’ must end with ‘D_CS’ and hitting escape cancels the label creation ui rather than the autofill suggestion. This is beyond tedious. I need to go for a walk now.
I have not used V9 yet, but this sounds like a horror story to me. Autocompletion is a great feature but it should always be an optional extra, and direct user input should always overrule whatever the computer suggests. Take for example a programming IDE. Often you get a dropdown box with suggestions when typing some word, but if you ignore that and just keep typing on like nothing happened, the IDE just accepts what you type.
It’s like those annoying internet search engines that do not even search for what you type in, but first replace your search terms with some more common words, and then give search results for those. Quite annoying.
