anyone can help to known how to change a value of a resistor in different variants using kivar?thanks
You need to read the documentation and look at the examples . . . then repeat that a few times.
(Category changed to External Plugin, KiVar is an external plugin . . .)
Were you able to solve your problem?
As @RaptorUK said, please check out the documentation. It’s all in there, including examples and a demo project you can try yourself. For a quick run-through, check out the short tutorial I presented at KiCon last year.
Btw: The latest version 0.5.0 finally supports top-level variants (which specify one choice per given aspect for each variant), as requested during the Q&A session of the same talk.
If you still have questions, just ask them here or in the KiVar Issue Tracker.
