I’m experiencing a similar problem, but encountered it a different way.
I was using 6.0.5 (release) for Mac, and installed plugins via the new PCM “Plugin and Content Manager”. They were working fine.
Now I upgraded to 6.0.6 (release) for Mac, and the plugins are no longer appearing in the menus or GUI.
I tried to uninstall and reinstall them in the PCM, but the problem persists.
To debug, I went to Preferences > Action Plugins and clicked the yellow ! icon button, here is the output …
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/SharedSupport/scripting/kicad_pyshell/__init__.py", line 25, in <module>
from wx.py import crust, version, dispatcher
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/wx/py/__init__.py", line 6, in <module>
from . import crust
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/wx/py/crust.py", line 16, in <module>
from .shell import Shell
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/wx/py/shell.py", line 28, in <module>
from .path import ls,cd,pwd,sx
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/wx/py/path.py", line 8, in <module>
import subprocess
File "/private/var/folders/3h/h0lsc1wx6ds311g4xqfxzhnc0000gn/T/AppTranslocation/C7860B19-1B1F-4542-BACD-7C280B78EFD9/d/KiCad.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.8/subprocess.py", line 64, in <module>
import msvcrt
File "<frozen importlib._bootstrap>", line 971, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 914, in _find_spec
File "<frozen importlib._bootstrap_external>", line 1342, in find_spec
File "<frozen importlib._bootstrap_external>", line 1314, in _get_spec
File "<frozen importlib._bootstrap_external>", line 1443, in find_spec
File "<frozen importlib._bootstrap_external>", line 1483, in _fill_cache
OSError: [Errno 34] Result too large: '.'
