Hi Sir,
I have read the documentation of Kipart, as below link :
https://xesscorp.github.io/KiPart/docs/_build/singlehtml/index.html
Since I already have installed Python in my computer before, I installed Kipart accordingly by command “pip install kipart”
I’ve found “kipart.exe” is installed under “D:\MyPrograms\Anaconda3\Scripts”, then I placed a simple “test.csv” file in the directory, content as below :
Pin,Type,Name
23, input, A5
90, output, B1
88, bidirectional, C3
56, tristate, D22
84, tristate, D3
16, power_in, VCC
5, power_in, GND
29, power_in, VCC
98, power_in, GND
99, power_in, VCC
59, power_in, GND
but I am not exactly know how to execute kipart.exe correctly
Firstly, I opened Anaconda prompt window, execute “kipart test.csv”, but nothing happened, I have checked the directory “D:\MyPrograms\Anaconda3\Scripts” and did not find a “test.lib” created by kipart.exe
then I open command window prompt and try again, no luck again
any suggestion would be very appreciated, thanks !
I am using Python version 3.7.4
