I am attempting to get KiKit working. To do so I followed the instructions at:
for installation on Linux. My OS is Pop!_OS 20.04, which is based on Ubuntu.
I upgraded the pip command to the latest version, installed setup tools, and installed KiKit, with this command sequence:
sudo pip install --upgrade pip
sudo pip install setuptools
sudo pip install kikit
I get this response to this command:
$ kikit --version
Traceback (most recent call last):
File "/usr/local/bin/kikit", line 11, in <module>
load_entry_point('KiKit==0.6.1', 'console_scripts', 'kikit')()
File "/usr/local/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 489, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/local/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2852, in load_entry_point
return ep.load()
File "/usr/local/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2443, in load
return self.resolve()
File "/usr/local/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2449, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "/usr/local/lib/python2.7/dist-packages/kikit/ui.py", line 15
raise RuntimeError(f"Fillet radius ({radius} mm) has to be greater than " \
SyntaxError: invalid syntax
What can be done about this error?
