Hi
I am trying to panelize a circular PCB using the kikat plugin - but it gives me some challenges…
I am not able to use the kikat command line to prepare the files for jlcpcb - due to DRC errors…
I finally managed to reduce most of them away, but the remaining ones seems to be for the 3 holes / entries for tooling / fiducials …
Settings used:
--tooling 'type: 3hole; hoffset: 2.5mm; voffset: 2.5mm; size: 1.5mm' \
--fiducials 'type: 3fid; hoffset: 2.5mm; voffset: 2.5mm; coppersize: 1.5mm' \
Any hints on how to get this sorted out - so that I can prepare files for jclpcb ?
