uh… nope it gets even worst:
C:\Program Files\KiCad\bin>pip install -U git+https://github.com/xesscorp/KiCost/
Collecting git+https://github.com/xesscorp/KiCost/
Cloning https://github.com/xesscorp/KiCost/ to c:\users\weird.tux\appdata\local\temp\pip-req-build-ucqpxr
Requirement already satisfied, skipping upgrade: beautifulsoup4>=4.3.2 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (4.8.0)
Collecting lxml>=3.7.2 (from kicost==1.1.2)
Cache entry deserialization failed, entry ignored
Using cached https://files.pythonhosted.org/packages/c4/43/3f1e7d742e2a7925be180b6af5e0f67d38de2f37560365ac1a0b9a04c015/lxml-4.4.1.tar.gz
Requirement already satisfied, skipping upgrade: XlsxWriter>=0.7.3 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (1.2.1)
Requirement already satisfied, skipping upgrade: future in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (0.17.1)
Requirement already satisfied, skipping upgrade: tqdm>=4.30.0 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (4.36.1)
Requirement already satisfied, skipping upgrade: requests>=2.18.4 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (2.20.0)
Requirement already satisfied, skipping upgrade: CurrencyConverter>=0.13 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (0.13.10)
Requirement already satisfied, skipping upgrade: babel>=2.6 in c:\program files\kicad\lib\python2.7\site-packages (from kicost==1.1.2) (2.7.0)
Requirement already satisfied, skipping upgrade: soupsieve>=1.2 in c:\program files\kicad\lib\python2.7\site-packages (from beautifulsoup4>=4.3.2->kicost==1.1.2) (1.9.3)
Requirement already satisfied, skipping upgrade: chardet<3.1.0,>=3.0.2 in c:\program files\kicad\lib\python2.7\site-packages (from requests>=2.18.4->kicost==1.1.2) (3.0.4)
Requirement already satisfied, skipping upgrade: idna<2.8,>=2.5 in c:\program files\kicad\lib\python2.7\site-packages (from requests>=2.18.4->kicost==1.1.2) (2.7)
Requirement already satisfied, skipping upgrade: urllib3<1.25,>=1.21.1 in c:\program files\kicad\lib\python2.7\site-packages (from requests>=2.18.4->kicost==1.1.2) (1.24)
Requirement already satisfied, skipping upgrade: certifi>=2017.4.17 in c:\program files\kicad\lib\python2.7\site-packages (from requests>=2.18.4->kicost==1.1.2) (2018.10.15)
Requirement already satisfied, skipping upgrade: pytz>=2015.7 in c:\program files\kicad\lib\python2.7\site-packages (from babel>=2.6->kicost==1.1.2) (2019.2)
Requirement already satisfied, skipping upgrade: backports.functools-lru-cache; python_version < "3" in c:\program files\kicad\lib\python2.7\site-packages (from soupsieve>=1.2->beautifulsoup4>=4.3.2->kicost==1.1.2) (1.5)
Installing collected packages: lxml, kicost
Running setup.py install for lxml ... error
Complete output from command "C:/Program Files/KiCad/bin/python.exe" -u -c "import setuptools, tokenize;__file__='c:\\users\\weird.tux\\appdata\\local\\temp\\pip-install-xx6vnb\\lxml\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record c:\users\weird.tux\appdata\local\temp\pip-record-yvzgcg\install-record.txt --single-version-externally-managed --compile:
Building lxml version 4.4.1.
Building without Cython.
ERROR: "xslt-config" non \u0160 riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
** make sure the development packages of libxml2 and libxslt are installed **
Using build configuration of libxslt
running install
running build
running build_py
creating build
creating build\lib.mingw-2.7
creating build\lib.mingw-2.7\lxml
copying src\lxml\builder.py -> build\lib.mingw-2.7\lxml
copying src\lxml\cssselect.py -> build\lib.mingw-2.7\lxml
copying src\lxml\doctestcompare.py -> build\lib.mingw-2.7\lxml
copying src\lxml\ElementInclude.py -> build\lib.mingw-2.7\lxml
copying src\lxml\pyclasslookup.py -> build\lib.mingw-2.7\lxml
copying src\lxml\sax.py -> build\lib.mingw-2.7\lxml
copying src\lxml\usedoctest.py -> build\lib.mingw-2.7\lxml
copying src\lxml\_elementpath.py -> build\lib.mingw-2.7\lxml
copying src\lxml\__init__.py -> build\lib.mingw-2.7\lxml
creating build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\__init__.py -> build\lib.mingw-2.7\lxml\includes
creating build\lib.mingw-2.7\lxml\html
copying src\lxml\html\builder.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\clean.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\defs.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\diff.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\ElementSoup.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\formfill.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\html5parser.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\soupparser.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\usedoctest.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\_diffcommand.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\_html5builder.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\_setmixin.py -> build\lib.mingw-2.7\lxml\html
copying src\lxml\html\__init__.py -> build\lib.mingw-2.7\lxml\html
creating build\lib.mingw-2.7\lxml\isoschematron
copying src\lxml\isoschematron\__init__.py -> build\lib.mingw-2.7\lxml\isoschematron
copying src\lxml\etree.h -> build\lib.mingw-2.7\lxml
copying src\lxml\etree_api.h -> build\lib.mingw-2.7\lxml
copying src\lxml\lxml.etree.h -> build\lib.mingw-2.7\lxml
copying src\lxml\lxml.etree_api.h -> build\lib.mingw-2.7\lxml
copying src\lxml\includes\c14n.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\config.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\dtdvalid.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\etreepublic.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\htmlparser.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\relaxng.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\schematron.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\tree.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\uri.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xinclude.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xmlerror.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xmlparser.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xmlschema.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xpath.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\xslt.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\__init__.pxd -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\etree_defs.h -> build\lib.mingw-2.7\lxml\includes
copying src\lxml\includes\lxml-version.h -> build\lib.mingw-2.7\lxml\includes
creating build\lib.mingw-2.7\lxml\isoschematron\resources
creating build\lib.mingw-2.7\lxml\isoschematron\resources\rng
copying src\lxml\isoschematron\resources\rng\iso-schematron.rng -> build\lib.mingw-2.7\lxml\isoschematron\resources\rng
creating build\lib.mingw-2.7\lxml\isoschematron\resources\xsl
copying src\lxml\isoschematron\resources\xsl\RNG2Schtrn.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl
copying src\lxml\isoschematron\resources\xsl\XSD2Schtrn.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl
creating build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\iso_abstract_expand.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\iso_dsdl_include.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\iso_schematron_message.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\iso_schematron_skeleton_for_xslt1.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\iso_svrl_for_xslt1.xsl -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
copying src\lxml\isoschematron\resources\xsl\iso-schematron-xslt1\readme.txt -> build\lib.mingw-2.7\lxml\isoschematron\resources\xsl\iso-schematron-xslt1
running build_ext
building 'lxml.etree' extension
creating build\temp.mingw-2.7
creating build\temp.mingw-2.7\src
creating build\temp.mingw-2.7\src\lxml
x86_64-w64-mingw32-gcc -fno-strict-aliasing -march=x86-64 -mtune=generic -O2 -pipe -fwrapv -D__USE_MINGW_ANSI_STDIO=1 -DNDEBUG -DNDEBUG -DCYTHON_CLINE_IN_TRACEBACK=0 -Isrc -Isrc\lxml\includes "-IC:\Program Files\KiCad\include\python2.7" -c src\lxml\etree.c -o build\temp.mingw-2.7\src\lxml\etree.o -w
Compile failed: command 'x86_64-w64-mingw32-gcc' failed: No such file or directory
creating users
creating users\weird.tux
creating users\weird.tux\appdata
creating users\weird.tux\appdata\local
creating users\weird.tux\appdata\local\temp
gcc -mno-cygwin -mdll -O2 -Wall -I/usr/include/libxml2 -c c:\users\weird.tux\appdata\local\temp\xmlXPathInit4lqmm1.c -o users\weird.tux\appdata\local\temp\xmlXPathInit4lqmm1.o
Could not find function xmlCheckVersion in library libxml2. Is libxml2 installed?
error: command 'x86_64-w64-mingw32-gcc' failed: No such file or directory
Command ""C:/Program Files/KiCad/bin/python.exe" -u -c "import setuptools, tokenize;__file__='c:\\users\\weird.tux\\appdata\\local\\temp\\pip-install-xx6vnb\\lxml\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record c:\users\weird.tux\appdata\local\temp\pip-record-yvzgcg\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in c:\users\weird.tux\appdata\local\temp\pip-install-xx6vnb\lxml\
C:\Program Files\KiCad\bin>pip uninstall kicost
Uninstalling kicost-1.1.1:
Would remove:
c:\program files\kicad\bin\kicost.exe
c:\program files\kicad\lib\python2.7\site-packages\kicost-1.1.1.dist-info\*
c:\program files\kicad\lib\python2.7\site-packages\kicost\*
c:\program files\kicad\lib\python2.7\site-packages\tests\*
Proceed (y/n)? y
Successfully uninstalled kicost-1.1.1
C:\Program Files\KiCad\bin>pip install libxml2
Collecting libxml2
Could not find a version that satisfies the requirement libxml2 (from versions: )
No matching distribution found for libxml2
Cloning https://github.com/xesscorp/KiCost/ to c:\users\weird.tux\appdata\local\temp\pip-req-build-p7d2bb
Complete output from command "C:/Program Files/KiCad/bin/python.exe" -u -c "import setuptools, tokenize;__file__='c:\\users\\weird.tux\\appdata\\local\\temp\\pip-install-v23d9y\\lxml\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record c:\users\weird.tux\appdata\local\temp\pip-record-aawaxk\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running build_ext
creating users
gcc -mno-cygwin -mdll -O2 -Wall -I/usr/include/libxml2 -c c:\users\weird.tux\appdata\local\temp\xmlXPathInitmouzjn.c -o users\weird.tux\appdata\local\temp\xmlXPathInitmouzjn.o
Command ""C:/Program Files/KiCad/bin/python.exe" -u -c "import setuptools, tokenize;__file__='c:\\users\\weird.tux\\appdata\\local\\temp\\pip-install-v23d9y\\lxml\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record c:\users\weird.tux\appdata\local\temp\pip-record-aawaxk\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in c:\users\weird.tux\appdata\local\temp\pip-install-v23d9y\lxml\
have to rollback on kicost
1.1
