xzf16
August 14, 2023, 9:34am
1
I try to modify a step model using KiCADStepUp to fit for the footprint in KiCAD.
In KiCADStepUp, I found that every think is very well, which is shown in the below:
But when I export the step file and then load it in the KiCAD footprint editor, I found there is a gap about 2mm between 3d model and PCB:
HFKC.FCStd (151.1 KB)
HFKC.kicad_mod (2.6 KB)
HFKC.step (511.9 KB)
I think this is because the user has set z=-1,91mm
to the part object(COMPOUND008_cp009), IIRC setting z to the elements inside(COMPOUND008_cp001-8) will fix the export issue.
xzf16
August 14, 2023, 10:07am
4
Oh I see, I need to use ‘export to KiCAD’ button instead.
Thanks
system
Closed
November 12, 2023, 10:07am
5
