I’ve loaded this board in the past, with FreeCAD/KiCadStepUp, though this time I always get the error
“name ‘holesB’ is not defined”
apparently interrupting the process on the bottom side tracks.
Any ideas?
@lmattcrisg
could you please update kSU wb?
Recently I’ve improved some routines and I missed some user case…
fixing loading tracks
Actually, I updated it first, as I do each time I want to use it. Then, seeing the result, I tried stepping back to an older version from GitHub, but I’m not sure I did it right - sure enough, I didn’t even get the version I used last time with that PCB
Oh well… now that I re-updated kSU everything went smooth: I hope you did anything in the meanwhile, otherwise I have something very weird going on here
may be you had to update the Addons Manager cache …
I did my last update as in the above llink…
anway happy to see your problem went away
