KicadStepUp export error
Not sure if this is a question for here or FreeCad.
I imported a GrabCad step model(ESP-32 Wroom) to FreeCad. I am trying to export it to KiCad using the KicadStepUp export. It is giving me an error ‘Gui.ViewProviderDocumentObject’ object has no attribute ‘ShapeColor’
Does anyone know how to correct this or should I ask on FreeCad?
Thanks,
Jeff
The StepUp author is @maui. I’d expect him to wander by at some point and give you an answer. Other’s may too.
Welcome to the forum.
Welcome to the forum @JRowe.
You only need to export from freecad as step. If it came from grabcad as a step originally you don’t even need to use freecad. Just put it in your 3dmodel directory and pull it into you footprint:
