I wanted to add nets to a netclass and with the pattern “CLK1_*” KiCad also includes also netname “CLK1”:
Is this an expected behavior or a bug?
Cheers
Hannes
Cheers
Hannes
It’s interpreted as a regular expression where * is zero or more of the previous character. CLK1 has zero _ , so it’s a match. For example CLK1_.*
might work for you.
Note that KiCad tests both simple pattern match and regular expression match, and if either matches, it’s a match.
That means it is a bug via full regex or lazy checks since
CLK1_* should only match CLK1_ CLK_M CLK1_P but it is matching CLK1 as well and thus _ is being ignored
Um, do you not understand that * means zero or more occurences?
$ grep 'password_*' /tmp/addr-change-stories.txt
Sometimes reentry of the password or providing a second factor by other means, e.g. SMS.
The _ never comes into play in this match.
But thats the point … it should.
The OP has a pattern request of /DIFF-TRX/CLK1_*
The expectation is it matches
/DIFF-TRX/CLK1_M*
/DIFF-TRX/CLK1_P*
But it is matching
/DIFF-TRX/CLK1
/DIFF-TRX/CLK1_M*
/DIFF-TRX/CLK1_P*
so how is CLK1 being caught when it should be failing because it does not satisfy the minimum of CLK1_
But it does, the minimum is CLK1. The * applies to the previous atom, which is _. Therefore it’s correct for there to be no _ at all.
The strings that CLK1_* matches are:
CLK1
CLK1_
CLK1__
and so forth.
If you had wanted at least one _, then the regex operator you want is +. * = {0,} and + is {1,} occurences.
You may be confused by shell globs which are a kind of regex, but with slightly different meanings for the operators. In a shell glob, * is actually .* in a normal regex.
mmm I guess so…
greedy matching… which means CLK1_+ would be better
If I had a dollar for every time I cursed the classic Unix editor for requiring me to for example use [a-z][a-z]*
to find the next word starting with a lower case letter because [a-z]*
matches the null string, I’d have retired years earlier. But now vim has implemented +
, albeit you have to escape it with \
, so [a-z]\+
works.
It matches nothing because it needs the string to end with 1 or more underscore. The regular expression must match the whole string, not only beginning of it.
Your string would match only ‘CLK1_’.
But “+” doesn’t work in KiCad it seems
For my specific problem I changed the query to “CLK*_*” because there were also CLK2 and CLK3 which I needed to include, but this only as side information
See my reply to Naib above.
That works, as a shell glob, meaning “CLK, something, underscore, something”.
KiCad tests it also as a regular expression, but it doesn’t match, because it means “CL, zero or more K, zero or more underscore, end”.
If you want a regular expression, that would probably be CLK._.+
, meaning “CLK, some character once, underscore, any character at least once”.
If this combo of features frustrates y’all the way it does me, consider giving this issue a thumbs up on Gitlab:
