[Kicad7] How to assign netclasses without a label?
I want to add clearance restrictions in Kicad7 for specific nets.
In Kicad6, I simply assigned the netclases to each net.
I don’t want to add labels because I have several nets where components are just connected to each other:
so adding classes it would look like this:
What is the best way to do that in Kicad7?
I think there is no best way currently, all options have pros and cons.
Currently I switch between two solutions (and have not really settled for a favorite solution):
  1. use normal labels (local/global), set the netclass with “assign netclass” from RMB-context menu and set label-textsize to some very small value
  2. use the new introduced netclass directive labels with the following settings:
  • set pin length to 0.01
  • set “Show netclass” to off
  • so only the netclass directive shape is drawn, and it is drawn directly on the wire. This reduces the schematic-clutter.
  • As 4 netclass-shapes are available this method allows for four differnet netclasses
  • to later search&find (and maybe replace/rename) the netclasses the “hidden field” checkbox in the search&find dialog must be checked
See picture:
Maik
Thank you very much mf_ibfeew!!
That works perfectly for me (for now), as I only need 4 netclasses. :smiley:
The way i manage this is via heirachical sheet and then apply classes based upon the sheet wildcard
Can you expand on what you mean? That sounds like a really handy system, but I’m not sure how you set a net class by a sheet instance variable.
(Edit: I think I understand immediately after posting. This is a way of using the net “path” with a given sheet in it for the net pass assignments?
So class x = /sheet1/* would grab all the nets in sheet instance sheet1?
I don’t get it :frowning:
Not a big expert on hierarchical sheets
If you aren’t already using multiple sheets, this isn’t a good option. But if you are doing many instances of a filter (or similar), this is a clean way of collecting all nets on a given sheet into one net class.
@Naib : for me the netclass-assignment based on sheet wildcards works only if I add labels to all nets in this subsheet.
Have I overlooked something?
could you attach a simple example to learn from?
Maik
