KiCad6 Win10: Found 2 unconnected pads
When creating the Gerber files, I first did a DRC test which showed me 2 errors. See image
It is, however, the case that the pads are connected by the foreground layer.
** Drc report for C:/Users/Lutz Müller/Documents/Kicad/Projekte/ZB2L3_Akkukapazitätsmeßgerät_Anschluss_am_Multimeter/ZB2L3_Akkukapazitätsmeßgerät_Anschluss_am_Multimeter.kicad_pcb **
** Created on 2022-01-08 15:32:53 **
** Found 0 DRC violations **
** Found 2 unconnected pads **
[unconnected_items]: Fehlende Verbindung zwischen Elementen
Local override; Severity: error
@(129,1100 mm, 91,4400 mm): Durchkontaktierungspad 2 [+3V8] von F1
@(144,7800 mm, 86,3600 mm): Durchkontaktierungspad 1 [+3V8] von J2
@(103,0000 mm, 109,0000 mm): Leiterbahn [Net-(J1-Pad4)] auf F.Cu, Länge 6,0000 mm
@(99,0600 mm, 106,6800 mm): Durchkontaktierungspad 4 [Net-(J1-Pad4)] von J1
** Found 0 Footprint errors **
** End of Report **
WE can’t tell that in that picture. It isn’t too uncommon to find these two fills aren’t actually connected. Can you manually find this connection on the board yourself? Just assigning them to the same net isn’t enough.
I checked again and found the errors. Without zooming in, I would not have found the two places. Conclusion check not only the pads, but also the narrow points of the conductor tracks.
