Kicad very laggy with large 160x160 6-layer board
When version numbers are important, always include the full version info from: Help / About / Copy Version Info This info is about 20 lines of text and looks like:
Version: 8.99.0-unknown-05b2b3c26e~178~ubuntu20.04.1, release build
	wxWidgets 3.2.2
	FreeType 2.10.1
	HarfBuzz 2.6.4
	FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, X11, xfce, x11
	Date: May  6 2024 18:07:05
	Boost: 1.71.0
	OCC: 7.6.3
	Curl: 7.68.0
	ngspice: 42
Locale:
	Lang: en_US
	Enc: UTF-8
	Num: 1.234,5
As I mentioned before, my Nightly is too old because it stopped updating (apparently on 2024-05-06). I do get another message, just telling me the file version is too new:
Error loading PCB ‘/home/paul/downloads/vme-wren.kicad_pcb’. KiCad was unable to open this file because it was created with a more recent version than the one you are running.
To open it you will need to upgrade KiCad to version 8.99 or later (file format dated 20240706 or later).
If 062db51f24 is the git commit hash (which I think it is), then that version is exactly a month old. That’s a long time in the 8.99 branch - can you try re-opening with a new nightly build please?
I’ts the one my distro (Ubuntu 24.04) gave me when using the nightly ppa. But i’ll test with the new GPU on monday first before i continue iterating
When did yo you last update your PC? ( 062db51f24 suggests shortly after 2024-07-16) Just running regular system updates also updates KiCad-Nightly when it’s installed via a PPA.
Hi Paul,
In case you’re interested, i get regular 8.99 updates on my Mint. This is the latest:
Version: 8.99.0-unknown-3f2b6f7ae0~180~ubuntu22.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.11.1
	HarfBuzz 2.7.4
	FontConfig 2.13.1
	libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.18
Platform: Linux Mint 21.3, 64 bit, Little endian, wxGTK, X11, cinnamon, x11
	Date: Aug 15 2024 22:07:11
	Boost: 1.74.0
	OCC: 7.6.3
	Curl: 7.81.0
	ngspice: 42
	Compiler: GCC 11.4.0 with C++ ABI 1016
Locale:
	Lang: en_AU
	Enc: UTF-8
	Num: 1,234.5
type or paste code here
Yea so the nightly PPA for ubuntu hasn’t completed successfully for a few weeks. Heh
Allright, got the new GPU and there is no improvement. Infact it seems a little bit worse actually.
Driver works, i can see a big improvement in graphics performance (furmark).
Tried again on my laptop (intel graphics 5500) and performance is smooth as it should be.
So i guess there is something wrong with the amdgpu driver on my machine.
Edit: this person seems to have had the same issue:
also here is my full version info
Version: 8.0.4-8.0.4-0~ubuntu24.04.1, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.5.0 OpenSSL/3.0.13 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.7 libpsl/0.21.2 (+libidn2/2.3.7) libssh/0.10.6/openssl/zlib nghttp2/1.59.0 librtmp/2.3 OpenLDAP/2.6.7
Platform: Ubuntu 24.04 LTS, 64 bit, Little endian, wxGTK, X11, ubuntu, wayland
OpenGL: AMD, AMD Radeon RX 5500 XT (radeonsi, navi14, LLVM 16.0.6, DRM 3.57, 6.8.0-40-generic), 4.6 (Compatibility Profile) Mesa 24.1.0
Date: Jul 17 2024 01:36:30
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.5.0
ngspice: 42
Compiler: GCC 13.2.0 with C++ ABI 1018
and graphics info
Graphics:
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 07:00.0 chip-ID: 1002:7340
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 24.1.0
compositor: gnome-shell v: 46.0 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
display-ID: 0
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.0 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi navi14 LLVM
16.0.6 DRM 3.57 6.8.0-40-generic) device-ID: 1002:7340 memory: 3.91 GiB
unified: no display-ID: :0.0
API: Vulkan v: 1.3.275 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: N/A device-ID: 1002:7340
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: N/A device-ID: 10005:0000
tried x11 and wayland no difference
