Kicad version 8.02 schematic drawing
Dear All
see attached pdf kicad enquire file
I have some question about the EDA schematic see attached drawing my request number 1 .
  1. Question 1
    I have connect the bus data in the traditional connection type, with bus wires, but during the ERC show me some warnings see connection model 1.
    If I using the model connection 2 don’t have any warnings,
    In the model 1 if I delete the warning and remake, after ERC move the warning on other lines
    why this happens?
  2. Question 2
    See the drawing enquire 2 I have some pins of the connector that are not connected, the pin in library are defined with passive, but if are not connected I have the error.
    If I try to connect at the particulary label NC I think that on the PCB hi connect all this pin together so is not a right way,. How is possible to fix this issue ?
  3. Question 3
    See the dwawing enquire 3, is the same question of the question 2
  4. Question 4
    See the drawing enquire 4, I have in this case a battery backup where the pin are defined power output and microcontroller pin VDD and GND are defined input pin.
    In this case there is a conflict with pin -of the battery with GND, on the GND is connected also another output power pin of the Ac/Dc, how I can fix this conflict.
    I have also other conflict , if I connect a bidirectional pin to VDD the ERC generate a warning.
Have also error because Dvcc1 is not connected direct to power 3.3V is possible to fix this error, because I need to have in the middle a switch to connect power 3.3v or battery backup.
KIKAD_ENQUIRE.pdf (253.2 KB)
  1. It’s always hard to tell the exact reason for soe ERC-errors from pictures and without the exact error-message. It’s more helpful to attach the zipped project (from Kicad main manager: File–>Archive project), so all volunteers are able to open the project and examine the errors themself.
possible mistakes:
  • no name (label) applied to the bus. For signals BUS0…BUS7 you should apply a label BUS[0…7]
  • just drawed the wires onto the bus. You have to use the “UNFOLD from BUS” command (right-click BUS–>context menu–>unfold from bus)
Your solution two just doesn’t uses a bus, instead all wires are directly connected by the labels.
To become familiar with busses:
  • look into example projects (for instance demo-project “interf_u”)
  • read the section “busses” in the schematic manual
  • start easy with a vector bus
  1. and 3):
    It’s up to you (the designer of the schematic) to judge the importance of a ERC warning. If you deliberately don’t want a connection on a pin you may just ignore that specific ERC warning.
    It’s also possible to place a NC-cross on such a pin:
  • You have to use the “nc-cross” command from the right side toolbar.
  • you must not use a label called “NC”. The ERC doesn’t interprets strings. A label called “NC” places a connection with the name “NC” (and therefore connects all pins with this “NC” wire)
  1. no guess without the example project
Hello
Thank you for yuor support, have fix the Issue, Sorry but I’m forget to give ERC-errors during my request.
