Hello!
Thank you for the v9.0.2, it does import “flat” LTspice schematics fine now.
The hierarchical projects cause import problems:
the sub-circuits are imported but occure in the same compartment
their symbols (the X1 and X2 in my example) are not the links to the sub-circuits
Here is the project to try and the result I get.
088-A6_FG1-9.zip (8.4 KB)
A2(3).zip (64.8 KB)
Please report this on GitLab using Help - Report a Bug
Testing the LTSpice importer requires these samples.
catBot:
If you want the hierarchical import to succeed more cleanly:
Try converting each .asc to a schematic and explicitly define the .subckt mapping.
Alternatively, edit the netlist to explicitly define .subckt structures that the new tool can recognize.
Thank you.
I’ll try and also - will provide a smaller test case.
(I’m on a business trip right now)
system
Closed
August 6, 2025, 2:37pm
5
