I notice that as installed the 3D models data is loaded into the footprints as only VRML versions , but the STEP models are also there , why not load these in , so that the STEP export works
Secondly the issue is awkward to fix given the libraries are read only and very tedious to do
Also in an existing design , is there any way in V6 to force the update of a footprint from the one on the board rather then only from the master library , ie make changes to the 3D entries on one footprint and push it to all similar footprints on the board without having to update the master library part ??
