Sprig
June 8, 2019, 4:23pm
1
KiCad V5.1.2 Stable
Date of this version is 05Jun19.
I have not been following the Developers Mailing List. Does anyone know if anything important has been fixed in the last three(3) nightlies?
ON EDIT:
Thanks @holger for pointing me in the right direction.
Launchpad Link - Use ngspice-30 for current nightlies and next releases
It appears to be a package change:
Nick Østergaard (nickoe) wrote on 2019-06-06: #8
I have pushed it for 5.1.2 as well as pkgrel 2.
5.1.2 has been out for quite a while. Are you sure this is new and not just a reupload?
Sprig
June 8, 2019, 4:31pm
3
I’m not certain of anything at all.
It may be a duplicate, but this is not clear.
For example:
KiCad V5.0.1_3
and
KiCad V5.0.1_4 are clearly different as the file sizes are different.
At least it is ngspice-30 (see https://bugs.launchpad.net/kicad/+bug/1821520 ). Maybe it is just a re-packaging with the current simulator.
And neither of them are 5.1.2… I think this is the relevant screeenshot:
Usually the number following the underscore is a packaging release number. Which would make sense as Nick says “pkgrel 2”, and in this context I would decipher that as “package release 2”. Unfortunately for us, you only gave that short quote and the link only goes to that comment. Reading the full bug report where that comment came from (bug number 1821520 ) it appears to be related to ngspice-30 as @holger also said.
I have asked on the dev list for doing the re-packaging also for macOS.
Sprig
June 10, 2019, 12:53am
7
Whoops!
As I have not yet been replaced by a robot, I am not 100% accurate in everything I do.
Does the pre 5.1.3 Nightly build include the ngspice update?
Sprig
June 10, 2019, 1:25am
9
How to tell?
ON EDIT: I do not see SPICE at all in the V5.1.3 Testing version; but I don’t remember where it was.
Second EDIT: I found it; but have no idea how to tell what ngspice version is installed.
To get the spice version, use @Holger useful trick
To get the ngspice version from inside KiCad, you have to do a trick:
Open empty eeschema window.
Edit a text box (T from the right column) and type in the following:
.op $ just a dummy command here
.control
version
.endc
.op just gives a simulation command, the .control section will return the ngspice version.
Now do Tools–>Simulator–>Run Simulation
and you will see the ngspice version.
Blockquote
holger
June 10, 2019, 8:15am
11
The Windows nightlies for 5.1.2 and 6: yes
For macOS see
system
Closed
September 8, 2019, 8:15am
12
