I just installed Kicad v6.0 and I wanted to make a footprint for a buck converter using the Footprint Wizard. I saw online that I can configure from that wizard the number of pads, pitch, width, etc.
But when I opened it, the Footprint Generators window is empty. Do I have to do some additional steps?
I checked now the first 2 paths and the scripting folder doesn’t exits.
I checked this path also C:\Users\username\Documents\KiCad\6.0\scripting\plugins and the folder is empty.
Is this a bug?
paul@cezanne:/usr/share/kicad/scripting/plugins$ ls -hl
total 184K
-rwxr-xr-x 1 root root 1,9K Jan 15 21:26 arc_test.py
-rwxr-xr-x 1 root root 6,0K Jan 15 21:26 bga_wizard.py
-rwxr-xr-x 1 root root 5,1K Jan 15 21:26 circular_pad_array_wizard.py
-rwxr-xr-x 1 root root 28K Jan 15 21:26 FootprintWizardBase.py
-rwxr-xr-x 1 root root 6,6K Jan 15 21:26 FPC_wizard.py
-rwxr-xr-x 1 root root 1 Jan 15 21:26 __init__.py
-rwxr-xr-x 1 root root 25K Jan 15 21:26 kicad_qrcode.py
-rwxr-xr-x 1 root root 7,8K Jan 15 21:26 microMatch_connectors.py
-rwxr-xr-x 1 root root 4,7K Jan 15 21:26 mutualcap_button_wizard.py
-rwxr-xr-x 1 root root 14K Jan 15 21:26 PadArray.py
-rwxr-xr-x 1 root root 8,8K Jan 15 21:26 qfn_wizard.py
-rwxr-xr-x 1 root root 6,3K Jan 15 21:26 qfp_wizard.py
-rwxr-xr-x 1 root root 7,7K Jan 15 21:26 qrcode_footprint_wizard.py
-rwxr-xr-x 1 root root 8,8K Jan 15 21:26 sdip_wizard.py
-rwxr-xr-x 1 root root 7,6K Jan 15 21:26 touch_slider_wizard.py
-rwxr-xr-x 1 root root 6,1K Jan 15 21:26 uss39_barcode.py
-rwxr-xr-x 1 root root 6,7K Jan 15 21:26 zip_wizard.py
For me,
/home/paul/.config/kicad/6.0/scripting
does not exist, It’s probably optional for extra stuff to be installed.
The other paths in
/home/paul/.local/share/kicad
are also empty on my system.
The script names in
are also the same as those footprint wizards, and it also makes sense to have them there, because they are a part of KiCad itself, and no user addons.
I have no idea why they are missing on your system (Or maybe the’re just misplaced? (Search for those file names). But the result for me is the same, I do not know How I could help further here.
Finally I reinstalled and now it works. @paulvdh now I have the scripting/plugins folder populated with the same scripts from your output.
But when I first installed that option was marked. Actually I didn’t change anything during installation I left all the checkboxes as they were.
