I want to exposure my pcb with my elegoo saturn dlp printer.
For that, i need the layout in a stl format.
But i did not find a way to create one since the last days.
I exportet the pcb as svg. I can open that in inkscape and here
it shows ok. But if i open it in freecad or in blender (for the extude)
i see only small lines, not the right thickness.
What is the easiest and right way to export from kicad to a stl ?
I hope someone have these informations for me.
And please with open source tools, like freecad, inkscape, blender and so onā¦
(No fusion 360 by example please)
NO, i want to āprintā only the bottom copper Layer of the board.
Short description. I want to expose the photo positive base material with my
elegoo saturn dlp 3d printer. For that, i need the invers buttom copper layer
as a stl file for the 3d printer. With that stl i only want to expose for 50 seconds.
I can plot the neded image as svg from kicad.
In inkscape, the image is right. But how i can import the svg in blender or freecad
with the right sizes (not only lines) for extrude the āimageā a few millimeters and export it
as an stl for the chitubox slicerā¦
Thank, i know this video.
But he is using Fusion360 for the convert path.
I can not use Fusion360⦠So i need the conversion
with inkscape and freecad/blenderā¦
Thanks eelik for the info.
I installed the Freecad addon kicadStepUpMod
I can open the kicad pcb file in freecad, but i see only the 3d design of the pcb.
No copper/pads.
Can you tell me, how to load the copper layout with pads here ?
Or have you a source for this informations ?
youtube or website etcā¦
I used file open dialog, then the kicad pcb file.
My design breaks with an
<class āPart.OCCErrorā>: Failed to create face from wire
Error. A other design opens, but only the board with the components.
In Kicad i have text on the copper layers. But this text is
not in freecad, when i import the tracks. Is it possible to
also include the text ?
Update:
I switch the text to layer soldermask and import that as dxf.
This not fine, but it worksā¦
But now i found a bigger problem.
I need the inverse of the āimageā before i extrude it.
How i can invert the object ?
Did someone know that ?
Very funny.
This IS marketing and nothing else.
Re inventing the wheel.
The value of this messy equipment makes up easily for a lot of quick runs in any pcb house.
@jos
i donāt think so. The equipment is here, and it is much easier to
crate that stl and then expose the pcb directly on the dlp printer
with a much bigger resolution as create a foil with the laser printerā¦
But anyone can do it however they wantā¦
