Maui great work!!
I really hope this step up support can be merged into the main code one day to provide native .step support.
Hi @mangelozzi
kicad devs are working for a direct integration of STEP using the same approach I did with FreeCAD:
converting STEP to VRML and display natively the STEP->VRML model in kicad…
This part is almost done using OCE, which is the main MCAD library engine of FreeCAD…
Then there will be the part to export pcb board and models to STEP… this will take longer I think…
my kicad StepUp tools are available now and they probably will cover the STEP exporting process until a full integration will be done…
kicad StepUp is covering:
- kicad_pcb to STEP exporting
- kicad_mod visual align 3D model over footprint
- generation of STEP model for pcb and parts configuring ‘bounding boxes’ and ‘minimum volume’ of 3D parts
- collisions detect for enclosure and footprint design
- exporting of VRML models with Material Properties (almost public feature)
Many of these features will remain in FreeCAD (MCAD) environment anyway…
Moreover the direction is the same: leaving VRML files coming from Wings3D or similar modeler and get only STEP 3D mechanical models library as the source for kicad 3D
That is the reason I’m calling for an official repository for 3D mechanical models
The StepUp made by @maui is a tool GUI and script developed for kicad ECAD MCAD collaboration and to be used with FreeCAD
Yes, unfortunately much longer. At the moment I’m thinking 1-2 years because of the API which needs to be developed to create plugins to manage PCB data. I should be working on the design of that API, but it makes no sense to start until the initial 3D work has been merged. If I didn’t care about the API and didn’t care about making the kicad code an even more unmanageable mess I could put in an IGES exporter in only 2 days - and maybe a STEP exporter using OCE in only 1 or 2 weeks.
Hi @all
I’ve added to kicad StepUp tools an external macro to export STEP to VRML with material properties, also if the model comes as a STEP multi-color fused part (i.e. coming from manufacturers or on line libs)
https://github.com/easyw/kicad-3d-models-in-freecad/blob/master/exportVRMLwColors/exportPartToVRMLwMaterials.FCMacro
this macro can be used after having aligned your STEP model to footprint and exported to STEP and VRML for kicad… if you desire an improved VRML model with not only diffused properties, but also with nice more material properties, you can select your part and run the macro… you will be asked to associate each color of the 3D MCAD model to a preset list of materials (i.e. metal grey pin, gold pin, black body, led blue etc…) aligned to @kammutierspule material list
Many thanx to Mario (@kammutierspule) for his useful work!
Please note that method will give you a small difference in color appearance for exported VRML models compared to your original STEP models, but it will add nice reflective effect to be used in raytracing view, available with the new 3D refactoring coming soon
Maurice
Hi Maurice,
Great tool, the demo looks great! Unfortunately I have some issues running the thing on my side.
I have a board and three components with 3D models, which I found online. I had the option at download to specify which format, so I got the VMRL and STEP versions. For simplicity, I am using the default KISYS3DMOD path (C:\Program Files\KiCad\share\kicad\modules\packages3d). I placed both files for each component in a subfolder at the path: boardAD/(files go here…).
The models needed some scaling and offsetting which I did in KiCad manually. When I ran the script, several errors are displayed. It properly loads the board, then add some components (not all) then displays the following:
boardAD/myfirstconnector.wrl error: reset values of scale to (xyz 111)
boardAD/mysecondconnector.wrl reset values of scale to (xyz 111)
(… as many times as this connector is present …)
boardAD/mythirdonnector.wrl reset values of scale to (xyz 111)
Basically, for all the components. The script did:
- load one connector with proper scale and offset
- load the second type of connector but wrong scaling and offset
- did not load the third type (not visible in the object list in FreeCAD)
For the third connector, the STEP file opens correctly in FreeCAD in standalone.
Any advice?
Cheers and thanks
Hi @bananabread
you are trying to achieve a mechanical representation of your pcb and components
so scale is mandatory 1:1 for all the 3D models
please spend some time reading the starter guide…
https://sourceforge.net/projects/kicadstepup/files/kicadStepUp-starter-Guide.pdf/download
there is a paragraph about “Create your own Library” which is very useful
All good library model should have
(model shapes/your3Dmodel.wrl (at (xyz 0 0 0)) (scale (xyz 1 1 1)) (rotate (xyz 0 0 0)) )
kicad StepUp tools can take care of offset and rotation, but I still would suggest you to use them only for enclosures or mechanical spaces or screws…
you can align and check if your model will fit the footprint, loading the footprint itself inside FreeCAD and align there the 3D model in MCAD way
have a look at this thread
Also have a read at this thread from the first post… you will see that someone found the same doubts and did some steps to improve the ECAD to MCAD collaboration…
also this thread may be very useful
Maurice
Hi Maurice - this looks really promising.
I have come across a small problem with importing a slightly odd shaped board. This is a curved board - sort of 'C" shaped but all that imports is a ‘D’ shaped segment of approximately half of the board.
It is correctly populated (or at least the part that I can see is correctly populated). Also I have only been able to import it as an .enl file.
Any advice?
John
Hi @John_Pateman
would you mind to share the board?
just the pcb edge would be fine or by a pm as you prefer…
your board edge segments create a closed path? (edge cuts layers had to be contiguous)
thank you for feedback
Maurice
He may check if he is getting any popup messages,
but I believe it is ok, otherwise, the board will be rendered as a square/rectangle.
Also overlapping is not allowed for mcad but it seems to me it is fine for 3d rendering…
Anyway, having the pcbedge in kicad format would solve the riddle
My fault - you were right Maurice - the board edge was not joined although even at max zoom I had difficulty seeing where the problem was. I think the sensitivity for detecting closure must be different between the 3d render and the StepUp macro? I originally got a rectangular board in 3D view until I adjusted the outline. When I tried to import the file in StepUp I got the segment but the board rendered properly in 3D view. Sorry!
John
MCAD needs precision… if you want a square you need a real closed path
I discovered on my road to MCAD that there is a nice function in pcbnew:
“Edit Item” segment properties…
there you can discover exactly the start and end of a segment and fix it properly
I always end up doing this to set an exact board outline. It would be nice if there was a more direct way of entering a board outline as numerical coordinates of a polyline. As it is importing a dxf is the most direct method
The problem with relying on the edit box is that the board i was having problems with is composed of arcs. Whilst using straight lines it would be easy to check the start and end points. The arc edit box gives a centre position and starting point accurate to 2decimals.
however the line segment is accurate to 5 or 6 decimals…
I think davidsrsb makes a good point - the ability to enter dimensions/starting points directly would be quite helpful in this sort of situation or indeed whenever designing to a specific size. I will try the dxf route another time.
I agree very much, but you could get a request from developers to code it by yourself
Kicad is an amazing community with many different point of views that I often don’t understand, considering that is an open source project aimed to be widely spreaded
The hardware fraternity at CERN believes that KiCad can do to PCB
design what the GCC compiler did to software, letting design and
development knowledge flow more freely in the open hardware community.
Anyway, apart some jokes, dxf import is a very good option to avoid those issues …
first thanks for a great plugin.
All of a sudden I can no longer open the newest plugin.
I have attached the error message from Freecad.
1.3.2.6 still opens without any problems
Hi @martin123
thank you for using my StepUp plugin…
Which version of tools are you using? The latest should be 3.1.1.6
## Constant definitions
___ver___ = "3.1.1.6" # added single instance and utf8 support
Referring to your error message you are using a very old macro…
The latest is named kicad-StepUp-tools.FCMacro and can be used as batch script or as a GUI
You can also add the kicadStepUpMod folder to your
%AppData%\FreeCAD\Macro and open directly .kicad_pcb files in FreeCAD
Where did you get the StepUp tools?
kicad StepUp tools latest
Please keep me informed
Hi maui
Have the latest verion from Sourceforge.
This is what i get, when I use kicad-StepUp-tools.FCMacro;
The part about kicadStepUpMod folder, do you mean I can directly open kicad_pcb files with “File -> Open”?
yes, you can directly open a kicad_pcb file with File Open Menu in FC
Referring to the error, please try to:
- delete or better rename your config ksu-config.ini file (it is located in
%HomePath%, in your case it should be inc:\Users\i7) - edit the file and configure your path to 3D prefix
- close and reopen FC and try the macro again
Moreover, I would suggest you to move from FC 0.15 to FC 0.16 which is the latest stable release, with a lot of improvements (still I have no issues with FC 0.15)
EDIT: enable Report View Panel in FC to see better the errors
Maurice
