Hello Goodnight. I’m using Google Translate, I’m Brazilian.
I have a problem with Silkscreen when I export the .dxf file to the FreeCad on my PCB.
The Silkscreen is far from the axis of the plate, and is not at actual size.
The .dxf of the tracks works perfectly.
How to proceed?
Thank you.
maui
#2
please check to have set the DXF export on KiCAD and DXF import on FreeCAD as int the KSU cheatsheet
and set export units to mm
It worked, thank you very much! It was a unit of measurement.
system
Closed
#4
