It seems that the official binary of Kicad does not support python (although there is a Python executable in the bin folder). Did I miss something (it seems to be an old problem) ? Is there still no hope to get one ?
Alternatively, if python is no more supported on Windows, this should be a big warning in the release notes.
in Windows it doesn’t support python v3 but it does support python v2, there is a problem with the graphic library and it is being worked out for v6.
Py 0.9.8
Python 2.7.18 (default, Apr 20 2020, 16:57:11) [GCC 9.3.0 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
Startup script executed: C:\Users\uestrada\AppData\Roaming\KiCad_v5_1_9\PyShell_pcbnew_startup.py
Application: Pcbnew
Version: (5.1.9)-1, release build
wxWidgets 3.0.5
libcurl/7.71.0 OpenSSL/1.1.1g (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.41.0
wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.73.0
Curl: 7.71.0
Compiler: GCC 10.2.0 with C++ ABI 1014
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Thanks,
I installed Kicad on WSL2 and uses VcXsrv on windows, this allows me to access Python3 (I still do normal work on the Windows side). I have not yet tested it extensively, my purpose is just to try to generate some layout for a connection matrix.
My projects are on Git, so it is not too bad to synchronize them for my limited purpose.
