I need to script KiCad with python3 for various reasons.
Default Kicad windows binaries are not built with “KICAD_SCRIPTING_PYTHON3” option “ON”.
I tried to build KiCad using msys2 but it seems wxpython 4 (supporting python3) has no msys packages.
I tried to build wxPython on msys, but this look to be quite a hard task as it detect a windows platform and try to build using VS (http://wxpython-users.1045709.n5.nabble.com/Install-wxPython-4-for-MSYS2-td5728732.html)
Is python3 support only on linux yet ?
Is it a plan to have a python3 windows build ?
You can have a py3 build on Windows but without wxpython. I do have an old 5.99 python3 build (with gcc) if you’re interested in. Or you might want to summon @nickoe to get you a fresh version.
From what I know most developers build with python support disabled (as it adds significantly to build time) so python issues are not really high on priority list. So we might wait until V6 to get py3 build on windows (I don’t see the team releasing windows version with py2 support). The best chance would be to build KiCad without python support with MSVC (this is doable now, and there should be some notes on the setup) and then work your way to get python. If you manage, I’d be happy to test it.
the ‘only’ stopper is wxpython 4 (with py3 support) built for windows msys2.
It would great if some developer could find a patch to build wxpython on msys2 @qu1ck did you get a chance to look at it?
I did, and it’s not trivial. Don’t have bandwidth right now to tackle that issue. Maybe later after I get other things I volunteered for out of the way.
