I re-installed KiCad a few days ago. Simply to use the Schematic program to draw a circuit. When I print it, the transistors ‘disappear’!
On searching this looks like it was a bug that was quashed?
But not in my version. Ubuntu
It may be necessary to delete the kicad settings otherwise the problem may recur.
“/home/USER/.config/kicad/6.0”
I have Linux Mint 20.3 but I think the path to the settings is identical.
ATTENTION: You lose all the settings, save the files before taking the test.
Hi All
Thanks for the suggestions. I did install from the site:- Install on Ubuntu | KiCad EDA
Which gave me this version. If I plot the circuit the transistors internal diagram appears. But printing it does not.
Maybe the Ubuntu repository is incorrect?
Regards
JohnB
Hi
Checking again. kicad is already the newest version (6.0.0-0rc1-202111191542+bf2b03b42f~115~ubuntu18.04.1).
If I re-install from that PPA, it installs the same version.
Not the ‘stable release’ latest version.
Hi jmk
I can upload a pdf of the circuit. Or a jpg. But the circuit prints with all but the collector, base and emitter.
But it plots. To pdf or printer. No issues.
But regards the version 6.0.7, I don’t understand why the apt update/upgrade still downloads an ‘older’ version.
Don’t bang your heads against a brick wall. I can plot diagrams…
Regards
JohnB
I think there was a situation where pre-release versions had a package version number that was based on the date 202111… and therefore sorted higher than any actual release version. This happened to some people earlier this year. Such is the hazard of tailgating pre-release versions.
The solution is to remove all packages of that pre-release, and also remove any mention of pre-release repositories in the system, then install following the documentation.
Hi All
OOPS! I installed the kicad-nightly as per the Mint install page.
It also doesn’t print NPN / PNP transistors. The version in help about:-
Application: KiCad
Hi jmk
WHERE does it say NOT for use on 32bit OS’ ??
I did not see that on any of the KiCad pages. Nor did the ubuntu install mention this.
If it is only for 64bit, surely the ‘downloads’ page should mention this?
