KiCad pcbNew printing black pages
I am using KiCad 6.0.6, usually I take a print to check the foot prints and the PCB size before moving on to production. I noticed that with 6.0.6 the print function is generating a blank page in Black & White mode. If I change to color I am able to get the prints but again the background was dark. As an interim I fixed with applying user theme.
Print preview in default settings. Its a Black screen.
Unfortunately I couldn’t attach more screenshots with default theme in Color mode. The background is still dark which was not the case in 5.x version.
On my Linux Box it appears to work normally with (probably) default settings.
Here output from: PCB Editor / File / Pint / Print / Preview
However, after twiddling about, I managed to get:
What I did was (In the Print dialog):
  1. Set the Output Mode to “Color” in A).
  2. Set the Print background color checkbox in B).
  3. Set Output mode in A). to B&W again.
When you set the Output mode to B&W, the Print background color setting gets grayed out, but apparently the setting of the checkbox itself does not get disabled.
This appears to be be a bug, and seems worth reporting on gitlab.
Can some people here give a confirmation (also for V6.99)
Application: KiCad PCB Editor
Version: 6.0.6-3a73a75311~116~ubuntu20.04.1, release build
	wxWidgets 3.0.4
Platform: Linux 5.15.0-33-generic x86_64, 64 bit, Little endian, wxGTK, xfce, x11
	Date: Jun 20 2022 15:49:56
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.83.1
	ngspice: 36
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
@paulvdh
Unfortunately I run the same Mint, but will confirm the same problem in 6.0.6 AND 6.99 when following your instructions.
With “Print Background Color” unchecked, I also get a proper image, as per first screen grab, for both 6.0.6 & 6.99.
This appears to be be a bug, and seems worth reporting on gitlab. Can some people here give a confirmation (also for V6.99)
confirmed and reported as #11625: print board: checkbox "Print background color" in Black&White-mode (#11625) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Thanks for looking it up. I added a remark on gitlab that KiCad V6.0.6 is also affected by this.
Confirmed on Windows 11 as well
Application: KiCad PCB Editor (64-bit)
Version: (6.99.0-2246-gab9c42d427), release build
	wxWidgets 3.1.7
	FreeType 2.11.1
	HarfBuzz 4.2.0
	FontConfig 2.14.0
	libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 11 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
	Date: Jun 28 2022 07:19:28
	wxWidgets: 3.1.7 (wchar_t,wx containers)
	Boost: 1.79.0
	OCC: 7.6.0
	Curl: 7.83.1-DEV
	ngspice: 37
	Compiler: Visual C++ 1929 without C++ ABI
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
