Kicad PCB file is listed as an older version and not visible
I am having an issue with multiple projects, and I would appreciate some help. I created a few designs under kicad version 8 and upgraded to version 9. Since updating, my projects and schematics are shown as being version 9 projects, but my board remains listed as a v8 board file. When I try to open these boards, I get a loading error that says that I need to upgrade to kicad version 9 (which I am running). The boards vias, nets, and pad data is listed but I can’t see anything other than a black edge cut layer. I have lost all of my work and I actually rebuilt one from scratch as a version 9 project, but I am now having the same issue with this redesign. Does anyone know what is going on?
First, are you 100% sure you’re not running v8? In any case, copy and paste here the exact version info from the problematic KiCad from Help → About → Copy Version Info.
Application: KiCad x64 on x64
Version: 9.0.1, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Do you have version 8.0.x installed as well? Assuming Windows 10 or 11?
If you’re double clicking on the .kicad_pcb file instead of opening it in the project manager then the OS may be trying to open it with version 8.
Also, the “Copy Version Info” button copies a bunch more stuff than what you’ve shown. May help someone diagnose the issue if the entirety of the version info is shown.
Thanks ill look into that when i get a chance. I dont think i have v8 installed but i dont underdtand how my board file could change from v9 to v8 without it being on my computer.
Did you potentially open the project file in v8 (before v8.0.9) after upgrading it to v9? It sounds a bit like the visibility bug. In that case, you can delete the .kicad_prl to reset the visibility settings.
That being said, I don’t know why that would cause the “black edge cuts layer” and there may be more going on here.
I had a similar issue in that if I opened the the pcb file from ‘file explorer’ then it would open in Kicad 8 not in 9.
I ended up removing Kicad 8 as I don’t use it and just save older projects as v9 as and when I need to.
Can you post the bad .kicad_prl file?
