I am new to Kicad. I like to know if it is risky if I choose auto placement and auto routing in kicad pcb . It must be obviously faster than doing above manually. Does it have any disadvantages?
Thanks in advance
Shhys
Thanks in advance
Shhys
It can be obviously faster to automatically place components until you realize a first pass on placement/routing is often not ideal. Auto routers will go for the shortest connect-the-dots (pads) approach; sometimes this is fine, sometimes not.
Does the auto placer know to put bypass caps close to their IC? What about placing to minimize a certain trace length? Does the auto placer know to keep those components handling 110VAC away from the 1.8VDC rail? Etc.
Auto placement requires a lot of effort up front giving weights to various nets. Experienced humans are more efficient at placement, orientation and multi-part unit selection than any software that I have used.
Autorouters are more competitive these days
Thank you for replies.
I dont use auto place or route.
It’s better to group components together that have a close relationshipb so that it is easier to debug a board problem.
And I like to control track routes so that power tracks are as direct as possible and signal tracks avoid noise sources.
I start a board with the enclosure outline, then place connectors.
