KiCAD PCB Antenna footprints
Here are; ready to use PCB Antenna library, footprints, documents, etc…
https://drive.google.com/file/d/0B38qWbX1O5CzR2Q4XzljY1NlcTg/view?usp=sharing
Why not create a project on GitHub, perfect for this?
I have not run the GitHub project before. I don’t know how to use github. :frowning:
Aren’t you supposed to have a .dcm file to go with your .lib file. I don’t see one in your zip file. Just the symbol library file “MyAntennas.lib” but not a “MyAntennas.dcm” file. Don’t we need that to see your symbols?
dcm file contains what you put into this dialog…
DCM File contains;
EESchema-DOCLIB Version 2.0
$CMP AN91445
F C:/KiCAD/MyLibs/Datasheets/AN91445.pdf
$ENDCMP
$CMP DM00024648
F C:/KiCAD/MyLibs/Datasheets/DM00024648.pdf
$ENDCMP
$CMP SWRA117D
F C:/KiCAD/MyLibs/Datasheets/swra117d.pdf
$ENDCMP
$CMP SWRA118
F C:/KiCAD/MyLibs/Datasheets/swra118.pdf
$ENDCMP
$CMP SWRU120B
F C:/KiCAD/MyLibs/Datasheets/swru120b.pdf
$ENDCMP
#End Doc Library
Here the “MyAntennas.dcm” file;
https://drive.google.com/file/d/0B38qWbX1O5CzV0hhOGQyUGM1NTQ/view?usp=sharing
ah HA! Now I see how the .dcm file works and how you typically edit it’s contents.
I edited the path in efem’s version so it pointed to where I put the .pdf’s and it is all working. Cool!
Learned yet again something new about KiCad. Thanks Joan and efem.
[I’m slowly figuring KiCad out and hope to make my first PCB and send it off to be built.]
Would you share these in the KiCAD libs on GitHub?
Best,
JAN
of course, yes. But I don’t know how do share on the Github. May be someone help me to do it. :slight_smile:
You register an account at github and read the how-to-guide that was made exactly for this purpose by them :wink:
The two things you need is ‘create a repository’ and ‘commit’.
All else is for team/bughungting/collaborative work and not really needed for stuff like this.
There is a desktop tool that you can install that makes this more comfortable: https://desktop.github.com/
No idea why there is no linux though… must be different there or built in already?!
[edit]
just seen that you will also or instead need the pull-request feature.
So same, register and then rock up at the link @jkriege2 posted and follow the red circles:
The librarians should then take care of it and comment/work with you.
Git was created by Linus Torvalds for Linux kernel development
Ah right, there was that. Remember having read about it.
