Kicad on tablet and external SSD over WLAN
HI,
I would like to run Kicad on a tablet but install it on an external SSD which is connected over WLAN. The reason behind it is that I want to be able to access projects on different locations. The diskspace on the tablet however is to small. I have already tried but Kicad does not seam to start.
Any idaeas what I could do?
KiCad isn’t designed for tablets or touch UI at all.
And tablets usually have ARM processors and without full OpenGL support (only ES). People have tried to get it running on Raspberry Pi which has similar hw than a typical tablet, but there hasn’t been much success.
EDIT: at least you should give much more techical information about your system. Hw, OS etc.
is there a viewer for schematic and pcb available? This would be sufficient.
You mean for KiCad native files? I don’t think so, although I may be wrong.
https://eyrie.io/ works pretty well for pcbs, don’t know about schematics.
Depending on usecase this could also be useful Interactive Html Bom Plugin for KiCad 5.0
You could also try https://www.rollapp.com/app/kicad
Honestly designing like that sounds terrible though. IBom is fantastic as a reference during assembly.
With a few mouseclicks you can make PDF files of schematics an PCB layers.
Also: Don’t overlook a simple piece of flattened dead tree carcass to print your schematic on for review. You can also make notes on it with some archaic utility called a “pen”.
These sheets are a bit flimsy though. you can put it on the surface of your tablet to have a flat back ground for making notes :slight_smile:
Thanks for all your comments.
I thing I found the problem: The OS is XP not W7 (as I said before). After uninstalling all KiCad and then installing latest version of Kicad 4, Kicad 4 worked. Then I tried to “upgrade” to latest version of Kicad 5. During installation I got a message from Firefox, which indicated a security problem. Is there a simple work around? If not I will upgrade to W7.
I tried to print a .pdf which would do the job, but when I selected to scale to pagesize, printing was stil at scale 1:1.
KiCad V5 has quite a lot of improvements over KiCad V4, and I would not want to go back.
They also use different sets of libraries and …
XP is pretty obsolete.
Have you ever considered installing a Linux distribution on your tablet?
Linux distributions are Open source & Free (as in Freedom).
Mint is a pretty decent choice for beginners:
https://linuxmint.com/download.php
If you’re curious but not commited then you can simply download an image, put it on a USB stick and boot from the USB stick (if your computer supports it)
There are a few different ways to generate a .pdf.
Eeschema / File / Plot / Output Format : Pdf
Eeschema / File / Print
On my Linux box this second option has “printer driver” that prints to a pdf file instead of to a printer (This probably is not a part of KiCad, but an external program). On Winoze you may have to install this as a separate program.
… and these will probably works slightly differently in KiCad V4 and V5.
You can also use .svg as output format, and view in any picture viewer or web browser.
