I developed a Eurocard board and ordered 10 assembled, unfortunately I have a bad surprise checking first board:
This module: [Mechanical_Sockets:Socket_DIN41612-CaseC1-AC-Male-64Pin-2rows
has two errors, one detected by ERC check for pin [24a] missing the ‘a’ in the name, and already corrected before Gerber generation, but the second error is very big :-((
The two rows ‘a’ and ‘c’ are completely in wrong position (mirrored), my guilt is that of not being careful enough and mistrustful, now I have a heavy work to do to recover these cards, sigh…
I don’t know if other DIN41612 connectors layout have similar problems.
So what do we do now?
I would suggest you fork the repository, fix them and make a pull request.
(It is open source after all. So you are able to fix mistakes made by others.)
It looks to me like all the DIN41612 male connectors (right angle) in that library are incorrect. Row a should always be closest to the connector body. I don’t know if there are variations within DIN41612.
Row A of a right angle DIN 41612 is always nearest the edge of the board.
You have to be careful about pin 1 with reverse or inverse DIN, I got caught out with some back to back cards long ago
Got it here (Norm-Database of University, Perinorm).
Row a is indeed row c.
Some nice info:
Types B, C, D, E, F, G and H can be connected with the corresponding Types Q, R, S, T, U, V.
Rows are in order, columns are inverse (contacts 1,2, … 23 of type C are connected with 32, 31, …, 1 of type R)
Thanks for confirming that. I have raised several issues on the github.
I ran the python script to check the footprints, and there are several failures relating to KLC.
Fixing the pin 24 and row order is quite easy, conforming to KLC is a lot more time consuming. Some of the issues may be fixed by the script, I need to install Python 3 to get that to work I think. I gave an error on Python2.7.
