Dear all,
I’m having trouble getting KiCad to utilize my dedicated Nvidia GPU (RTX 2000 ADA) when rendering 3D models in raytracing mode.
While rendering with raytracing enabled, the GPU usage remains at 0%, and my CPU runs at 100%. In contrast, the GPU is used correctly in normal (non-raytraced) 3D view.
I’ve already tried the following without success:
- Reinstalling GPU drivers
- Forcing KiCad to use the Nvidia GPU via the Nvidia Control Panel and Windows settings
Has anyone encountered a similar issue or found a solution?
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
KiCad’s raytracer is a software raytracing system. It does not use any GPU no matter what brand.
Application: KiCad x64 on x64
Version: 9.0.3, release build
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
OpenGL: NVIDIA Corporation, NVIDIA RTX 2000 Ada Generation/PCIe/SSE2, 4.6.0 NVIDIA 572.16
Date: Jul 8 2025 05:19:33
Boost: 1.88.0
OCC: 7.9.1
Curl: 8.13.0-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_DE
Enc: UTF-8
Num: 1.234,5
I had this issue since KiCAD 8 already…
I also have a Dell laptop with RTX 2000. On that computer, the GPU is used 100% while rendering, and the image is rendered very fast, and still, I don’t know what are the settings differences between these two machines…
One of them is probably not using raytracing, or else one of them has a much faster CPU than the other and so it appears as though one is being accelerated. KiCad’s raytracer cannot use your GPU, and it is not a realtime renderer.
Thank you for your answer, I found the main difference, and it is kind of silly… Always I thought that my laptop is using the GPU to render because the render was way faster than on my workstation, but the main differences are the screens. The laptop is a full HD packed with i7 gen-12 16 cores, and the workstation is i7 gen-12 20 cores, but with a 4k screen. I always rendered in fullscreen…now it makes sense why it was way slower.
