it seems that in kicad nightly the following functions are missing:
GetTimeStamp (for EDA_ITEM, BOARD_ITEM, PAD, TRACK, MODULE)
SetTimeStamp (for EDA_ITEM, BOARD_ITEM, PAD, TRACK, MODULE)
Is there anyone that can point me to the related commit?
my pcbnew details:
Application: Pcbnew
Version: (5.99.0-1014-gaa95ff10d), release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Build date: Mar 1 2020 21:58:32
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
@Seth_h
thanks…
for ‘SetTimeStamp’ it seems now it can be done only when creating an object and cannot be modified after its creation… is that correct?
Yes. In V6, objects will have a set unique ID that can never change. These are used to dereference items in groups, sheets and rooms as well as tracking generated vs originated items.
it seems the function doesn’t return a Legacy Timestamp conversion from UUID
is there a way to assign an UUID to a trace when creating it in python?
i.e. (as I do in Kv5): new_track = pcbnew.TRACK(pcb) new_track.SetStart(p1) new_track.SetEnd(p2) new_track.SetWidth(FromUnits(w)) new_track.SetNet(Nn) new_track.SetLayer(layer) new_track.SetTimeStamp(tsc) pcb.Add(new_track)
The AsLegacyTimestamp() and related functions will be removed before v6 is released. These functions are only to ease the transition to UUID while we still utilize the older schematic file format. Once we not long save to the legacy format, all timestamps will be converted to UUID on read and there will be no output of legacy timestamps anymore.
The UUID will be assigned when creating the object and cannot be changed (by design). Is there a need to set specific UUIDs?
Stitching vias, Fielding vias, Track rounder Action Scripts use to set a specific TimeStamp to identify vias or tracks added by the script(s).
In this way it is (was) possible to erase i.e. only vias added using via stitching script among all the vias of the board.
