Mylium
February 8, 2025, 8:55pm
1
When executing kicad-nightly
/usr/bin/kicad-nightly: line 3: 12816 Segmentation fault (core dumped) /usr/lib/kicad-nightly/bin/kicad "$@"
I run with gdb and got:
Starting program: /usr/lib/kicad-nightly/bin/kicad
/usr/lib/kicad-nightly/bin/kicad: error while loading shared libraries: libkigal.so.9.0.0: cannot open shared object file: No such file or directory
[Inferior 1 (process 13048) exited with code 0177]
Uninstalling and installing again doesn’t help.
The crash should be fixed tomorrow.
The reason gdb
doesn’t work when called like that is that /usr/bin/kicad-nightly
is a wrapper script on Ubuntu and it’s setting some environment variables (see debian/rules · dailybuild · KiCad / KiCad Packaging / kicad-ubuntu-builder / KiCad Daily Package · GitLab )
You should be able to launch GDB if you do something like . /usr/share/kicad-nightly/kicad-nightly.env
first
jmk
February 9, 2025, 3:14am
4
This Kicad nightly starts, but crashes when an attempt to open a project is made. I don’t now if this is the “fixed tomorrow” version (see message by @craftyjon ) or the version mentioned by the OP.
The previous version (downloaded six hours before the one shown below) would not open at all.
Version: 9.0.0-rc3-66cbc8127b~182~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.18
Platform: Linux Mint 21.3, 64 bit, Little endian, wxGTK, X11, cinnamon, x11
Date: Feb 8 2025 14:52:01
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.81.0
ngspice: 43
Compiler: GCC 11.4.0 with C++ ABI 1016
KICAD_IPC_API=ON
Locale:
Lang: en_AU
Enc: UTF-8
Num: 1,234.5
jmk
February 9, 2025, 3:26am
6
Thanks, I didn’t want to unnecessarily create an issue.
m852
February 9, 2025, 6:54am
7
jmk:
OCC: 7.6.3
For this reason, it is not possible to update and install the application if FreeCAD is installed on the system.
Mylium
February 9, 2025, 9:45am
8
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
Platform: Ubuntu 22.04.5 LTS, 64 bit, Little endian, wxGTK, X11, ,
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.81.0
ngspice: 43
KICAD_IPC_API=ON
Locale:
Lang: en_US
Enc: UTF-8
Num: 1,234.5
Can be executed as root. I see its not just my case, so will wait for an update
dsa-t
February 9, 2025, 4:09pm
9
Mylium:
I you remove/rename KiCad settings folder, it will also start until you open any project.
Ubuntu 22.04 has libgit2 version 1.1.0, which was old enough to crash in our usage.
An updated KiCad build will be available in the ppa eventually.
jmk
February 9, 2025, 11:36pm
10
Nightly is working again with this package:
Version: 9.0.0-rc3-9b184afb43~182~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
OpenGL: Mesa, NV106, 4.3 (Compatibility Profile) Mesa 23.2.1-1ubuntu3.1~22.04.3
Date: Feb 9 2025 14:52:12
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.81.0
ngspice: 43
KICAD_IPC_API=ON
Locale:
Lang: en_AU
Enc: UTF-8
Num: 1,234.5
system
Closed
May 10, 2025, 11:37pm
11
