Hello everyone
The last version of Kicad v6 nightly can now export the format HyperLynx.
For Ubuntu 18.10 install kicad-nightly_201904092302+89d2e67~94~ubuntu18.10.1_amd64.deb
Command line
/usr/bin/pcbnew-nightly
See picture
Hello everyone
Command line
See picture
Cool! So one can use the expensive fieldsolver.
By the way, there is an open source field solver, openEMS written by the university
of Duisburg, Germany which is based on matlab / octave.
I never tried it, but it would be good to support the openEMS fieldsolver, as
it is free.
And …
it can read hyperlynx:
http://www.openems.de/index.php/Tutorial:_Importing_with_hyp2mat.html
Cheers,
Ludwig
I believe openEMS can import Hyperlynx format either directly or via a script https://github.com/koendv/hyp2mat
Hi
I’m trying to do some simulations in OpenEMS using hyperlynx files exported by kicad. There are some problems:
Hello
There is also Pyopenems, a python script to convert Kicad pcb to Hyperlynx
I have never tried it
Here is how to set parameters of substrate in openems when they are wrong in hyperlynx file exported from kicad:
CSX.Properties.Material{1}.Property.ATTRIBUTE.Kappa = kap;
CSX.Properties.Material{1}.Property.ATTRIBUTE.Epsilon = er;
CSX.Properties.Material{1}.Primitives.Box{1}.P2.ATTRIBUTE.Z = subs_thick;
