Has anyone had the problem that KiCad crashes when you have drawn a simple schematic with voltage source, two resistors, LED and a transistor, and you forgot to define a model for the transistor?
In 7.0 it opens the simulator window, and when you try to run an operating point simulation you get some error message in the spice output field (lower left), but at least it doesn’t crash.
This is an example circuit I did just to test this out. I discovered it in another schematic before that.
It simulates just fine if I go to properties for the transistor and choose a spice model file.
If not, crash of the whole KiCad application as soon as you klick the simulation button in the upper toolbar or choose simulte from the Inspect menu.
(I know that it is development version etc. and developers can choose whether to leave the bugs for the last minute or fix earlier. But I’m still curious to hear if someone else has the same problem.)
There isn’t anything interesting on the left outside the screenshot, just a connector that is excluded from the simulation.
Todays and yesterdays nightly both crash the same way.
Version: 7.99.0-1.20230308git74a9d79.fc37, release build
wxWidgets 3.2.1
FreeType 2.12.1
HarfBuzz 5.2.0
FontConfig 2.14.1
libcurl/7.85.0 OpenSSL/3.0.8 zlib/1.2.12 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.1 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.51.0
Platform: Fedora release 37 (Thirty Seven), 64 bit, Little endian, wxGTK, KDE, wayland
Date: Mar 8 2023 18:16:47
Boost: 1.78.0
OCC: 7.6.3
Curl: 7.85.0
ngspice: 39
Compiler: GCC 12.2.1 with C++ ABI 1017
KICAD_SPICE=ON
