I’m trying to build 7.0.6 stable on an Intel Mac with 13.4.1(c) (Ventura) using kicad-mac-builder. It runs for a long time, then fails; the first few lines are for context:
checking whether we are using the Intel C++ compiler... no
checking whether we are using the IBM xlC C++ compiler... no
checking whether clang++ supports C++11 features by default... no
checking whether clang++ supports C++11 features with -std=gnu++11... yes
checking for ar... ar
checking if C compiler (clang -mmacosx-version-min=13.4) works with SDK/version options... configure: error: in `/Users/jeff/go/src/github.com/gmofishsauce/kicad-mac-builder/build/wxwidgets/src/wxwidgets':
configure: error: building C++ programs doesnt work, try using --with-macosx-version-min with a different OS version or omitting it entirely.
See config.log for more details
make[3]: *** [wxwidgets/src/wxwidgets-stamp/wxwidgets-configure] Error 1
Then in ./build/wxwidgets/src/wxwidgets/config.log I find:
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "wxWidgets"
| #define PACKAGE_TARNAME "wxwidgets"
| #define PACKAGE_VERSION "3.2.2.1"
| #define PACKAGE_STRING "wxWidgets 3.2.2.1"
| #define PACKAGE_BUGREPORT "wx-dev@googlegroups.com"
| #define PACKAGE_URL ""
| #define __BSD__ 1
| #define __DARWIN__ 1
| /* end confdefs.h. */
| int
| main ()
| #ifndef __INTEL_COMPILER
| choke me
| #endif
| return 0;
This is really odd, because the documentation says I must have clang, but the Intel documentation says __INTEL_COMPILER is only defined for the “old”, g++ based compiler. And in the first line of the context, above, it says checking whether we are using the Intel C++ compiler... no.
So of course the #ifndef in that tiny program fails.
Can someone help me with this? Edit: one other add:
$ clang --version
Apple clang version 11.0.0 (clang-1100.0.33.17)
Target: x86_64-apple-darwin22.5.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
