Have been using KiCad-Librarian for a long time for bulk merging of local project libraries into my own master library, but regrettably it seems not to be compatible with the new v6 file formats and doing this within KiCad itself seems very cumbersome because copy and paste in the library editor doesn’t even have any keyboard shortcuts.
Will the awesome functionality of KiCad-Librarian be incorporated into KiCad v6
No. This isn’t an ‘official’ Kicad package. It is strictly 3rd party. Check the link you provided. I can’t really tie any of the developers to this forum so I can’t help much with that.
Earlier I found a link to the project on the compuphase website but I can’t find it again and it is hidden from menus as far as I can tell.
@hermit
Oh sorry, I thought you meant the KiCad contributors.
Yes I did post an issue report there.
@eeintech
Yes, did you not read my original post?
Anyway, bulk merging of libraries seems to be the main culprit for me (copying or moving more than one symbol in a single operation)
If this can be done with the KiCad library tools please tell me how.
@Kharar Use Git to add and merge parts to your master library, don’t use local libraries
If you still want to use local libraries, it’s only a text merge away (no need for GUI), but I wouldn’t recommend it.
Footprints are one file for each footprint. To add a bulk of footprints to a lib you simply copy their files into the folder of the lib you wish to add them to. You shouldn’t need a tool for that?
Symbols is another matter. There’s one file for each symbol lib. It could be a little more tricky to add symbols to a lib in bulk.
Yes I am aware of the simplicity of footprints - not a problem. (I meant symbols, sorry)
Symbols however is a real pain - this is where KiCad-Librarian has been a godsend - until now.
It can be done using a text editor, if you have tons of spare time and already know what you are doing, not really a suitable option IMHO. (I’m not familiar with git merge)
Hence the original request/post.
Anyway I seem to be just repeating myself …
Well, to each their own. But, you are kinda dead in the water with this unless the authors take it up. Like I said, I don’t remember seeing any of them on this forum. http://www.compuphase.com/electronics/kicadlibrarian_en.htm @sprig hasn’t been active for about a month but it looks like he used it.
No need for merging, just use Git like you would normally.
Check current status
$ git status
On branch main
nothing to commit, working tree clean
Add symbol to your libraries
Check new status
$ git status
On branch main
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git restore <file>..." to discard changes in working directory)
modified: SYMBOLS/Capacitors.kicad_sym
no changes added to commit (use "git add" and/or "git commit -a")
Great, capacitor library was modified.
Check diff (better use GUI tool to view changes like meld)
I think I fail to understand the point, I mean I already know how to use git to the level that is described here so far.
The procedure I need made easier is the adding or transfer of symbols, in your guide that is step two which is not further explained above.
As far as I understand git cannot help me with that.
In your original post you mentioned what you do is:
My solution is NOT to use local project libraries, instead directly push parts to you main libraries. This can be done at part level, bulk of parts, project, etc. you decide when you merge more parts in. You have one set of libraries and that’s it. They are always backed up, you can always revert, basically all the advantages of Git. It works well for KiCad libraries, it’s all text and easy to decipher.
I think we are not on the same page here… how do you “directly push parts to you main libraries”?
Thing is, my own master library (KICAD_SYM file) is already on git, I also know how the maintaining of it works.
What I am looking for is simply an easier way of batch copying multiple symbols from various local symbol libraries into the master symbol library file (which I do keep global of course).
To my regret the symbol editor only imports the first symbol in a symbol library file, hence it is currently useless for this purpose. A simple text editor can do much better but it is a tedious process.
If i understood you correct, i do not think this is possible right now with a simple straight forward solution.
If i were you, i would checkout the origin branch, open editor and copy paste into a buffer lib, close editor, checkout your target branch and open editor again to copy it back from the buffer lib.
