There is this project that I made a year ago in kickad 7.0 under windows. I opened the project again in version 8.0.7 under linux, and noticed that on the PCB editor, after I move components that are connected to the GND plane, the program freezes for 3-5 seconds and then resumes. While the program is frozen, I can hear my laptop fans ramping up, and any action performed in this time period will be applied after the program unfreezes e.g. if I zoom in/out when it is frozen, when it resumes, it will perform the zoom. The freezing does not happen when I move components or vias that are not connected to the GND plane.
The same thing happens when using ctrl-z regardless of the undo action or the component to undo.
All of this does not happen on the schematic editor.
I tried disabling some heavy 3d models that this project contains but this did nothing. I also ran other projects (both mine and other’s) of similar or higher complexity and I couldn’t replicate this behavior. I also deleted fp-info-cache but it also didn’t help.
Probably something in this project causes this, and maybe some aspect of the GND plane. I don’t know any ways to debug this, or to somehow rebuild this project to be optimized for kicad 8. Could someone with better knowledge of Kicad have a look at the project to see what is wrong?
Here is a the project in question.
Version: 8.0.7-1.fc41, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 9.0.0
FontConfig 2.15.0
libcurl/8.9.1 OpenSSL/3.2.2 zlib/1.3.1.zlib-ng brotli/1.1.0 libidn2/2.3.7 libpsl/0.21.5 libssh/0.10.6/openssl/zlib nghttp2/1.62.1 OpenLDAP/2.6.8
Platform: Fedora Linux 41 (KDE Plasma), 64 bit, Little endian, wxGTK, X11, KDE, wayland
OpenGL: Intel, Mesa Intel(R) UHD Graphics 620 (KBL GT2), 4.6 (Compatibility Profile) Mesa 24.2.4
Date: Dec 2 2024 00:00:00
wxWidgets: 3.2.6 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.8.0
Curl: 8.9.1
ngspice: 43
Compiler: GCC 14.2.1 with C++ ABI 1019
