Every time i want to open the Cvpcb-editor to assign footprints to my schematic symbols, the window openes, the idle-cursor appears and never go away. The application seems freezed and i only can terminate the whole KiCad
Same when search for parts. Selecting them from a library work, but search will never return and freezes KiCad also.
Whatās wrong?
Iām using latest KiCad 4.0.7 on Windows 7 64-Bit, on HP ProBook 650G Core i5 with 8Gig RAM.
Ok, i removed the KIGITHUB environment variable from the settings and the window now openes.
But there is an error message telling that KiCad canāt load some libs from Github. I hope i do not use themā¦
Wouldānt it be even smarter to download them to local computer?
Thanks Rene for the hint. Unfortunately this does not work (for me). I could remove all libs, but in the next step to download them from github, it get an error message
I think my Problem is that iām behind a Proxy server, which could not be set in Windows-Version of KiCad?!
Also, i do not get all the paths and library files and such. Maybe iām confused⦠why is this so complicated? As far as i know until now, KiCad is written in Python and uses git to access the libs from Github. Git should be able to handle proxies, so why isnāt there an setting for it? I mean, we are on Version 4.x not 0.x beta ;-)))
Kicad is written in c++ and it does not use git to access libs but it uses the github API to get zip archives of the lib. (This is how the github plugin works.)
But there also exists a python script that can download all footprint libs using git.
This does not setup kicad though you need to add the downloaded libs manually using the footprint library wizard. (add local libs)
I see. Thanks for pointing this out.
I downloaded and execute the script, but it does not download anything either.
āError loading fp-lib-table from gibhubā
The same proxy problemā¦
Yeah, i did it that way now, also. This is how:
1.) Download https://raw.githubusercontent.com/KiCad/kicad-library/master/template/fp-lib-table.for-github
2.) Write a little Shell-Script to build the libfile from the content. E.g. from the line (lib (name Capacitors_SMD)(type KiCad)(uri ${KISYSMOD}/Capacitors_SMD.pretty)(options "")(descr "Capacitors, surface mount"))
i took āCapacitors_SMD.prettyā, prefixed it with āhttps://github.com/KiCad/ā and also add suffix ā/archive/master.zipā, i get this download-URL: āhttps://github.com/KiCad/kicad-library/Capacitors_SMD.pretty/archive/master.zipā.
3.) Download the archive using wget
4.) Extract the contents into a temporary directory (e.g. c:\temp) and rename the extracted directory from āCapacitors_SMD.pretty-masterā to just āCapacitors_SMD.prettyā.
5.) After doing this for all files, i removed all folders in āC:\Program\KiCad\share\kicad\modulesā and move the downloaded libs from temp-dir here.
6.) Last, put the content of this table āhttps://raw.githubusercontent.com/KiCad/kicad-library/master/template/fp-lib-table.for-prettyā into ā%APPDATA%\Roaming\kicad\fp-lib-tableā
After starting KiCad i could access all libs, and it now has the performance it expect. This also works behind a proxy
