KICAD DXF Export
Dear Team,
I need to extract the DXF files from the below PCB file which was created using Kicad.
https://github.com/weirdgyn/Driverino-Shield
I need the DXF to contain the exact location of the main 4 connectors shown in blue.
May I know how to do it.
Regards
HARI
Your image shows an Auxiliary Origin (at lower left corner):
When you generate the DXF from the Plot menu, select to use the Auxiliary Axis As Origin.
Export of DXF is in: Pcbnew / File / Plot, the same dialog as for generating Gerber files.
You can set the plot format to either Gerber, Postscript, SVG, DXF, HPGL or PDF.
Can you please tell me what is Auxiliary axis
  1. Pcbnew / Help (If this does not work, then install the manual first).
  2. Manual is also available @ https://docs.kicad.org/
  3. Read chapter 11.3. Setting coordinates origin
This appears to be the standard Arduinno UNO layout. You should be able to find the dimensional location of these features with a good internet search. Try searching for “Arduino UNO dimensional drawing” or something similar.
