I have footprint library directory in /usr/share/kicad/modules/ and its not showing up in the footprint browser as a library.
Were is the correct place for footprints?
just placing it in the right folder isn’t enough.
in PCBnew you also have to add the library in Preferences/Manage Footprint Libraries
Additionally: Do not place personal libs into a system folder. The next update will delete it!
I placed them in non system paths I didn’t know updates clobber things in system paths.
This is a system path. Place personal libs into your home folder.
They aren’t in the system path.
I am confused now? Did you place your libs into /usr/share/kicad/modules or somewhere else?
Because whatever you think. That directory is a system directory. You need root rights to write to it for a reason. And the kicad installer will definitely overwrite it.
Its in a sub directory in home path.
I think you are looking for other question than above question. What is your actual issue? If it is about the footprint browser, then @Anders_Wallin give you the solution, which is to add your library path into the “Footprint Libraries table”… So I’m also confuse.
