I was trying some differential pair functions, such as Skew and lenght matching, and my KiCad crashes even try to route those diff. pairs.
I’ll try to strip to strip all my work related stuff, but before that has anyone any advise, or what to do. This is an old Win 10/64 machine with 6GB of ram
Application: KiCad x64 on x64
See if you can strip this project down to a minimum and still show this error. Then submit it to the issue tracker. You can mark it confidential so that only the developers can view it
Before you do that, check for extra overlapping tracks using the “show tracks in outline mode” function. If there are extra tracks, the length tuner won’t show a correct result.
I can confirm this issue. for me it crashed on a board where no other traces were present at this time. interestingly I was able to work around the crash:
while routing a long section and then pressing V to via to the bottom plane it crashed. once I confirmed the routing of the section before the vias and then only routed a short section with vias it did not crash anymore.
Some silly questions: How do you submit something to the issue tracker?
KiCad didn’t crash when I deleted all the extras. But I still don’t understand why the info on bottom of the screen shows different things about different pairs.
I’ll tease it a bit in the evening. I’ll try to tune and reroute diff. pairs. That would be a nice a feature set, if it worked.
