Kicad crashed and restarted
OS: Windows 11
Kicad Ver :7.07
Kicad crashed and restarted when I try to edit the symbol properties, adding the net label, adding the global net label, adding the hierarchial label etc. Not able to fix it. Tried to restart the system. Changed from 3 monitor to single display also. but no issues
Do you have any PlugIns installed ?
I didn’t. May I know where can i find the plugins.
Thanks-Arum
You can see if you have any PlugIns installed from the Plug In and Content Manager . . .
. . . but if you don’t then your issue is NOT related to this one :
Installed the plugins. But same issue continues
It’s the other way around. There is no need to install them. The thread linked to describes crashes of KiCad that are probably linked to installed plugins, so to get more stability you should UN-install the plugins, but if you had none, there is nothing to uninstall either.
As Paul mentioned, you don’t need to add PlugIns . . .
Have you tried running KiCad “As Administrator” ?
Please do not advocate users to run KiCad as administrator. It will risk corrupting their file permissions by doing so.
Administrator has nothing to do with impacting crashes here.
@Arumugam_Elumalai If you opted into data collection, you can provide us with the unique id in Preferences > Data Collection to take a look
Did you check the GitLab issue tracker, if there is already a bug descriptions that fits the bug you are experience? I searched for it and found some that maybe related, maybe not. If there is no description of your bug already, can you create a new one?
And please add more detailed versions info (From Help->About KiCad ->Copy Version Info). Also check if this happen on all (and new) projects or just a few. If it only happens in some or a single project(s), upload a project that causes the crash.
More information could also be helpful: Did you use the mouse or keyboard shortcuts? When exactly does this happen?
How can I share the data to you?.
Thanks-Arum
Its opening without any issues.
Post the id string from here
ec54f3a1-e7e5-4ea8-8766-06969dd455ef
Good news is, we have crash reports and it’s related to fonts.
However figuring out why is another question
Try the latest 7.0 testing build
https://downloads.kicad.org/kicad/windows/explore/7.0-testing
You can use the install ending with -x86_64-lite.exe
