When exporting a *.kicad_pcb file to dxf with KiCad-cli, is there a way to export the holes w/ actual diameter? Just outputting the F.Cu or B.Cu copper layer has a small circle where the hole will go, but it is not the actual hole diameter. There doesn’t seem to be a way of exporting the pads.
KiCad-cli command: kicad-cli pcb export dxf -l F.Cu -o PCBf.dxf “MyPCB.kicad_pcb”
Doc “PCB DXF export”: KiCad Command-Line Interface | 7.0 | English | Documentation | KiCad
What is the intention? Why do you want a DXF with the actual hole size?
I need a few of the traces to handle high current. For the prototype, I am planning on laser-cutting copper sheet and soldering them over the existing traces. I can change the hole size manually, but every time I make a change, I have to do it over again. If it is easy to export the hole size over the dxf, it would help.
Making bus bars from copper with a laser cutter is an interesting solution. That sure needs a hefty laser cutter.
The KiCad part is simple though. Just set the Drill marks to Actual Size for the Plot format: DXF output.
Edit: Oops, I missed the “cli” part.
Unfortunately there doesn’t seem to be a CLI option (I may write a bug report, as there should be a CLI option matching all of the GUI options) but in my tests the DXF exports with full-sized holes regardless? It might also be that the hole size option has no effect for DXF even in the GUI, I’m not sure.
EDIT: yes, in my tests 1) the drill size option is ignored for GUI DXF plots and the holes are always actual size, and 2) CLI DXF plots also make holes actual size.
Thank you for your research and post, Paul. This will work fine.
