I use the following plugin for via stiching:
when I execute it, the following error occurs:
Do you have any idea what’s the reason for this? I use KiCad Version V6. In the old KiCad Version it worked fine.
Best regards
Fabian
Best regards
Fabian
Get correct version of the script for your kicad version
Thanks, this works. Only important thing is to delete numbers/dot of the dezipped folder.
If I don’t correct the name the plugin isn’t found in KiCad.
