I installed KiCad 9 and would like to check if the following behaviors are normal.
Under KiCad 8, All TestPoint_Pad footprints on my pcb were edited to remove the silkscreen contour and courtyards. I could select either the footprint or the pad of a TestPoint_Pad, and edit whichever I wanted to modify.
Under KiCad 9, All TestPoint_Pads appeared as simple footprints. Double clicking them only allowed editing the footprint properties, not the pad properties. As an attempt to fix this, I changed their footprints in the schematic editor and updated the pcb. From this, double-clicking the TestPoint_Pads gave access again to the pad properties, and I could edit the footprint properties by selecting between the pad and the courtyard. The thing is, I wanted to remove the courtyard and silkscreen contours. After removing the courtyard, the problem happened again : double clicking the pad only allowed accessing the footprint properties (pad properties no longer accessible). This brings one question : how can I keep the courtyards of smd components and remove those of the TestPoint_Pads ?
I also experienced the following change: Under KiCad 8, all TestPoint_Pads had their value shown in silkscreen by default. After installing KiCad 9, all values disappeared from the silkscreen layer. After changing the TestPoint_Pads footprints in the schematic editor, the Reference would show on the silkscreen layer, but not hte Value as before. I had to edit the footprints locally so as to change the layer of the Value from fabric to silkscreen, and remove the Reference visibility.
KiCad version used :
Application: KiCad x64 on x64
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: NVIDIA Corporation, NVIDIA GeForce GTX 660/PCIe/SSE2, 4.6.0 NVIDIA 475.14
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
