Kicad 9 physical stackup keeps changing when moving from mm to mil
kicad 9.04 physical stackup keeps changing when moving from mm to mil.
I have a certain stackup but the Kicad keeps changing 3 parameters (one of the dielectric layer’s height, and the epsilon-r on two other layers).
Every time I close and re-open the PCB file, the physical layers under “File–>Board setup–>physical stackup” keep changing.
Furthermore, how to make sure the GERBER files I create reflect the stackup I really meant?
I included the .pcb file as well.
Regards,
Yt
C to C Adapter.kicad_pcb (857.8 KB)
Probably related to the grid bug mentioned below.
I am not sure why it has changed, but I am unable to repeat the problem on 9.0.4 .91 Testing
